2003 Other Pontiac Models Vibe has pulsating vibration when
2003 PONTIAC
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRISTINEP
The front passanger side tire hit a curb denting my rim a bit. Could this cause a vibration when I accelerate that pulses? I can really notice it when I am going between 40 and 55 mph.
Jan 3, 2008 at 1:07 AM
MMPRINCE4000
  • 8,548 POSTS
Yes.
If you are lucky you may just get a rebalance (if it can be balanced).
You should also check the tie rod ends, ball joints, control arm and bushings for damage.
More than likely you will have to replace the rim.
Take it to a reputable alignment shop to check for other damage.
Mar 31, 2008 at 12:19 AM
