1996 Pontiac Grand Am O2 Sensor Location
DECKJ
  • 7 POSTS
hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?
Aug 23, 2006 at 12:34 PM
MIKEYBDMAN
  • 623 POSTS
[quote:47446d34a0="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:47446d34a0]
which engine do you have?
Aug 23, 2006 at 12:35 PM
DECKJ
  • 7 POSTS
[quote="Mikeybdman"][quote="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote]
which engine do you have?[/quote]
i have a 3.1 v6
Aug 23, 2006 at 12:36 PM
MIKEYBDMAN
  • 623 POSTS
[quote:4bc284fe8d="Mikeybdman"][quote:4bc284fe8d="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:4bc284fe8d]
which engine do you have?[/quote:4bc284fe8d]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.
Aug 23, 2006 at 12:39 PM
DECKJ
  • 7 POSTS
[quote="Mikeybdman"][quote="Mikeybdman"][quote="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.[/quote]
thank u very much. you responded quite quickly too. i think i know where it is then. there isnt anything i could be getting it mixed up with is there?
Aug 23, 2006 at 12:42 PM
MIKEYBDMAN
  • 623 POSTS
[quote:1ffc3c7d1c="deckj"][quote:1ffc3c7d1c="Mikeybdman"][quote:1ffc3c7d1c="Mikeybdman"][quote:1ffc3c7d1c="deckj"]hi i am going to replace an o2 sensor on my 96 grand am gt. i have heard it is on the exhaust pipe in front of and in back of the cat converter. i only see the sensor behind the converter and it is the one before that i need to replace. if you can tell me where it is it would be very helpful. is it on the manifold?[/quote:1ffc3c7d1c]
which engine do you have?[/quote:1ffc3c7d1c]
On a V6 model the HO2S1 is located in the rear exhaust manifold. Right before it connects to the exhaust pipe. The HO2S2 is located behind the cat converter.[/quote:1ffc3c7d1c]
thank u very much. you responded quite quickly too. i think i know where it is then. there isnt anything i could be getting it mixed up with is there?[/quote:1ffc3c7d1c]
Nope. Should be the only sensor with wires going to it in the exhaust manifold.
Aug 23, 2006 at 12:43 PM
Suggested Repair
On the 3.1 V6, replace the upstream oxygen sensor (HO2S1) in the rear exhaust manifold, just before it connects to the exhaust pipe. The downstream sensor (HO2S2) is behind the catalytic converter. The upstream sensor should be the only wired sensor in the exhaust manifold.
Conversation Summary
The owner of a 1996 Pontiac Grand Am GT with a 3.1 V6 needed the location of the oxygen sensor ahead of the catalytic converter and could only see the sensor behind it. The expert said HO2S1 is in the rear exhaust manifold just before the exhaust pipe, while HO2S2 is behind the converter, and confirmed it is the only wired sensor in the manifold.
