2003 Pontiac Grand Am Ignition Locked
BIGGIN2005
I was wiring my stereo in my 2003 grand am se and something happened and my ignition locked up i was told there was a plug that has like a plunger inside that if i was to stick a small screwdriver in it would release the ignition but having trouble finding it if anyone could help please do
Sep 17, 2007 at 1:56 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f9729836ea="biggin2005"]I was wiring my stereo in my 2003 grand am se and something happened and my ignition locked up i was told there was a plug that has like a plunger inside that if i was to stick a small screwdriver in it would release the ignition but having trouble finding it if anyone could help please do[/quote:f9729836ea]
HI
IF YOU ARE TO REMOVE THE IGNITION SWITCH
ITS ON THE BACK OF IT
IGNITION SWITCH LOCATED BEHIND THE IGNITION
KEY
THAT PLASTIC THING YOU ARE LOOKING FOR SHOULD BE INSTALLED ON THE BACK OF THE SWITCH
YOU MUSTOF HIT IT WHEN PULLING OR INSTALLING THE RADIO
GOOD LUCK
Sep 17, 2007 at 2:23 PM
Suggested Repair
The plastic release plug with the plunger is on the back of the ignition switch, which sits behind the ignition key. It was likely bumped while removing or installing the radio; access the back of the switch to release the locked ignition.
Conversation Summary
The owner of a 2003 Pontiac Grand Am SE said the ignition locked up while wiring a stereo and could not find a plug with a plunger that a small screwdriver was supposed to release. The expert said the ignition switch is behind the ignition key and the plastic release piece is on the back of the switch, likely hit during radio work.
