It wouldn't hurt to replace the alternator, if it's making noise. The noise you're probably hearing is the bearing which will eventually need replacing anyway. As long as the volt meter gauge is around 14 to 15 volts or as long as the battery warning light is not on, (depending on which one you have), you're ok. Take it to advance auto they'll check your battery and charging for free. Good luck :)
SPONSORED LINKS
Monday, February 12th, 2007 AT 3:46 PM
