2004 Pontiac Grand Am Electrical Issues
LEGALMAMI
I have a 2004 Pontiac Grand Am SE w/about 55,000 miles. The other day I was driving and came to a stop, when I tried to unlock my doors w/the power lock switch they would not unlock. I tried it a few times and after a few times they worked. That same evening, I went to start my car and it would not start, when I turned the key it just made a clicking noise. My lights and radio and wipers all were still working fine. I got a jump from a friend and the car seemed fine until the next evening. I was rolling up my windows and as I hit the power window button my headlights and all my dash lights dimmed everytime I tried to roll up my windows. I took the car to a garage, they checked it, said there is nothing wrong with the car. My battery and alternator appear to be fine. I don't agree, there has to be something wrong. Any ideas???
Sep 10, 2007 at 8:30 AM
SERVICE WRITER
  • 9,123 POSTS
IT wouldn't surprise me if it was the battery. Check the battery cables bolts with a wrench as see if they are tight.
Sep 10, 2007 at 8:47 AM
LEGALMAMI
Thank you, I will try that.
Sep 11, 2007 at 3:03 AM
Suggested Repair
Check the battery cable bolts with a wrench and tighten them if loose. A poor battery connection can cause intermittent locks, a clicking no-start, and lights that dim under load even when the battery and alternator test fine.
Conversation Summary
The owner of a 2004 Pontiac Grand Am reported intermittent power door locks, a clicking no-start while lights, radio, and wipers still worked, and headlights and dash lights dimming when using the power windows. A shop found nothing wrong and said the battery and alternator appeared fine. The expert suggested checking that the battery cable bolts are tight.
