1997 Pontiac Grand Am Wheel Rubs Fender
GRRRY
I was driving and slid into a curb, and now whenever i turn right the passenger side front wheel rubs against the back of the fender. The wheel looks like it got pushed back an inch or two, and the alignment is messed up. Also when driving over 30 mph you can hear and feel a little vibration, i was wondering what needed to be replaced?
Feb 13, 2006 at 11:32 PM
BUDDYCRAIGG
  • 2,262 POSTS
you will have to inspect and replace as needed.
steering knuckle
hub bearing
tie rod end
lower control arm
strut
Dec 31, 2008 at 8:54 AM
Suggested Repair
Inspect the passenger-side front suspension after the curb impact and replace any damaged parts as needed, including the steering knuckle, hub bearing, tie rod end, lower control arm, and strut.
Conversation Summary
After sliding into a curb, a 1997 Pontiac Grand Am GT has a passenger front wheel that sits back, rubs the fender when turning right, vibrates above 30 mph, and has poor alignment. The expert advised inspecting and replacing the steering knuckle, hub bearing, tie rod end, lower control arm, and strut as needed.
