94 Grand Am 2.3 quad-4 sohc vin.code 3 180000 miles,
ALL OTHER MAKES ALL OTHER MODELS
DARREN SCHULER
Running on 1&2, 3&4 not. Have checked injectors and replaced one that was not completly closing(#4),all injectors spraying.Checked spark (#3) weak plug had 125000 ohms resistance,replaced all.Coils between 5000 & 6000 ohms (1-4)(2-3),no short to cover.Multi spark not as bright as I think maybe it should be but all equal.No unusual noise,power steering pump turning,exhaust manifold 1&2 heats up,3&4 doesn't (first clue) plugs 3&4 very little soot,cylinder end of plug housing/ground staying silver, little discolorization on electrode(2nd Clue).It doesn't seem to shake quite as bad but still scratching my head.Whats next?
Dec 31, 2006 at 3:29 AM
SERVICE WRITER
  • 9,123 POSTS
Ignition coil housing and boots are real common on this one.
Dec 31, 2006 at 9:46 AM
DARREN SCHULER
Just installed new coils and housing,no luck. Going to start over and recheck everything. More ideas? Is this the proper place to reply to suggestions?
Dec 31, 2006 at 10:29 AM
SERVICE WRITER
  • 9,123 POSTS
Maybe check compression in the bad cylinders. Did you replace the boots for the plugs?
Dec 31, 2006 at 3:45 PM
MATHIASO
  • 1,209 POSTS
what is wrong with the car?
please explain...
Jan 1, 2007 at 3:48 AM
