89 XJS REAR WINDOW
1989 ALL OTHER MAKES ALL OTHER MODELS
REX
ON MY 89 XJS V-12 CONVERTABLE THE PASSENGER SIDE REAR WINDOW DOE NOT GO UP LIKE THE DRIVER SIDE WHEN RAISING THE ROOF ANY EASY REASON
Mar 1, 2007 at 5:56 AM
DAVE H
  • 13,383 POSTS
we do not have the reset procedure .. contact your local dealer for this procedure
Jan 5, 2010 at 9:27 PM
LEMONLOVER
Wow what a lame reply! I own this demon car 1989 Jag XJS and do battle with the Lucas wiring daily. So... if the top is raising and lowering like it should, 1st - check the convertible top pump and fuses. They are hidden away behind the seats (open the storage compartment) on the passenger side. Is anything leaking? Theres a 2 blade fuse, is it blown? OK could be a relay or and this is a big or because 9 times out of ten its this, check a skinny black wire attached to something metal. These old cars slip their grounds all the time and you will spend a ton of money & time for no reason. If all the wires appear to be sound, go to the console area in between the seats. The wood veneer lifts when you remove 2 screws at the very front of the console storage box. Pull and lift. You should be able to see the roof/rear window swith along with the front window switch wiring. Check all the wiring and naturally the black ground wire. The wiring harness releases from the switch by pressing in the tabs on opposing corners. Clean up the switch and replug. Does it work? If not, go back to the convertible roof lift pump and switch around the relays. Anything? Chances are that is the other windows are working fine and there are no leaks and if the wiring is ground and secure AND if the switches are gunk free, that it is a relay. Do not buy one from these online greed mongers, you can get relays for 1 dollar each at any local sal
vage yard.
Aug 18, 2012 at 5:00 PM
