2002 Pontiac Grand Am Cold Clutch Limp
BUDDADUDE
I have a Pontiac Grand Am Se 2002, 2.2L DOHC and has about 80K+ on the mileage, this is the first major problem I've experienced with it. The clutch becomes limp, has no resistance at all when the weather drops to around 40 to 50 degrees fahrenheit, I have to pump it several times before the resistance goes back. I noticed that when it's a normal day, about 70 to 80 degrees fahrenheit the clutch is normal and doesn't show any signs of limping. I took it to a Firestone car repair shop and they didn't see anything wrong with it, unfortunately it was a warm day when I went so it wasn't showing signs of limping. I told them my story about the cold weather incident and they just smiled at me and said that it doesn't make any sense. I don't know much about cars so I hope you guys could help me with this one. Thanks and have a nice day.
Mar 2, 2007 at 5:04 AM
CHEVY22
  • 1,375 POSTS
hi
have you checked the fluid level and condition yet , if the fluid is dirty it may be contaminated , possibly water , if it does look dirty i would start by bleeding the system until all of the original fluid is exchanged and see hwat happens , and if you still have a problem we can go from there
thanks
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 12:00 AM
Suggested Repair
Check the clutch fluid level and condition. If the fluid looks dirty or contaminated, possibly with water, bleed the system until the original fluid is fully exchanged, then recheck the clutch.
Conversation Summary
The owner of a 2002 Pontiac Grand Am with a 2.2L engine reports that the clutch pedal goes limp and loses resistance in about 40 to 50 degree weather, requiring several pumps to restore resistance. The clutch feels normal in warmer weather, and a shop found nothing wrong on a warm day. The expert recommends checking the fluid level and condition and, if it is dirty or contaminated, bleeding the system until the original fluid is exchanged.
