Car won't start
G.A.PARADISO
I have a 2003 pontiac grand am. 67,000 miles. Six Cylinder.
It worked fine yesterday then when I went to pick up a pizza last night it would not start, not a sound, nothing.
Only started when I jumped it.
Battery eye us green. Barely makes a sound when the key us in the slot ( you know, the door open sound)
Is it a battery, starter or electrical? :shock: :shock:
Aug 18, 2007 at 11:18 PM
  • 75,988 POSTS
[quote:fe13f3d150="g.a.paradiso@att.net"]I have a 2003 pontiac grand am. 67,000 miles. Six Cylinder.
Is it a battery, starter or electrical? :shock: :shock:[/quote:fe13f3d150]
The little eyeball green looking color in it can fool you
that is good.
When was the last time you've change battery- get it tested then comeback
Aug 18, 2007 at 11:27 PM
HUGH247
[quote="rasmataz"][quote="g.a.paradiso@att.net"]I have a 2003 pontiac grand am. 67,000 miles. Six Cylinder.
I have a 2002 Grand AM, 48000 miles, same model, with a similar problem.
The car labors to start, but does. It wouldn't start one time last week and I had to get it jumped. Has started regularly since, but think I'm gonna get let down and stranded again sometime soon.
Battery check shows it is is fine, but I notice that the radio clock/stations need resettting every time I get the car started. Looks to me like starting is shorting something out (don't think it's the radio though).
Any suggestions where the short out might be occurring?
H of Long Island
Sep 1, 2007 at 5:51 PM
  • 75,988 POSTS
[quote="hugh247"][quote="rasmataz"][quote:db655c91a0="g.a.paradiso@att.net"]I have a 2003 pontiac grand am. 67,000 miles. Six Cylinder.
H of Long Island[/quote:db655c91a0]
When was it last tune-up and battery disconnection.
How did you check the battery-the best way to test the battery is load it with atleast 250-300 amps on it and watch the battery voltage if it goes below 9.6 volts-my way I replace it
Triple check all your connections from the battery to engine to starter or do a voltage drop test on the cables.
Check the MAP/CKP sensors. Could also be fuel pressure problem
Sep 1, 2007 at 8:18 PM
  • 75,988 POSTS
[quote="hugh247"][quote="rasmataz"][quote:52568a6ad7="g.a.paradiso@att.net"]I have a 2003 pontiac grand am. 67,000 miles. Six Cylinder.
H of Long Island[/quote:52568a6ad7]
How did you check the battery-the best way to test the battery is load it with atleast 250-300 amps on it or disable the ignition and use the starter as a loading device. and watch the battery voltage if it goes below 9.6 volts-my way I replace it
Check the MAP/CKP sensors. Could also be fuel pressure problem'Ignition switch problema.
