2002 Pontiac Grand Am Noise on driver side
AWYATT
  • 2002 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 55,000 MILES
I have a rattling noise under the hood when I go over a bump. It just started and is only noticeable when driving at slow speeds. It seems to be coming from the driver side, maybe under the hood. It sounds almost like a creaking noise. I'm afraid the motor is going to fall out or a wheel will fall off! Also, when I drive in a confined area like an alley, I hear squeaking sounds coming from the wheels?
Any clues? I would like to have an idea before I go to a mechanic!
Wednesday, February 25th, 2009 AT 1:14 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car put on stands, grasp each tire and push/pull both horizontally and vertically, looking for any movement, which would indicate bearings, ball joints, bushings or loose struts.
Friday, February 27th, 2009 AT 9:08 AM
