2002 Pontiac Grand Am car wont start
SHAUN1606
  • 2002 PONTIAC GRAND AM
2002 Pontiac Grand Am 4 cyl Front Wheel Drive Manual
my car will not crank over, but the starter is engaging and turning
Sunday, June 20th, 2010 AT 10:42 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, June 20th, 2010 AT 10:46 PM
