Engine turns over but wont start?
TS_CRACKER
  • 2002 PONTIAC GRAND AM
Engine Mechanical problem
2002 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
car turns over wont start replaced alot of stuff from crankshaft possition sensor ti ignation module got fuel to the engine did the alarm reset did plugs u name did it
Tuesday, August 3rd, 2010 AT 10:58 PM
  • 109,885 POSTS
Are you getting spark? When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Wednesday, August 4th, 2010 AT 6:58 PM
ONLYME2
My car was towed to a garage because I had somewhat the same problem, we've checked everything else, but the garage guy put it through some diagnostic thing and the outcomes was some "computer chip re-boot" who knows what that was but anyway he provided me a note in case it ever happens again and it did at least several times. (Saved me a few times already)
The note reads:
Turn your key to on position for 10 minutes.(Do not start the engine), your security light should be blinking on and off and once it goes out, turn your key to off for 10 seconds and back to on again to see if your security light blinking, if not then turn your engine. If it continues to blink repeat the 10 minute process again. But if that doesn't work for you I guess you have other car issues. GOOD LUCK!
Thursday, August 12th, 2010 AT 1:37 PM
  • 109,885 POSTS
That is the process for over riding the theft system. As far as the chip, most likely something in the steering column.
Thursday, August 12th, 2010 AT 11:31 PM
