2002 Pontiac Grand Am car wont start
LOCKEDOUT02
  • 2002 PONTIAC GRAND AM
Computer problem
2002 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
wont start due to key not being read by computer was told is there any way I am able to reset computer myself
Saturday, March 13th, 2010 AT 3:50 PM
THEPHANTOM1492
Is the security light blinking? If so, put your key in the ignition, turn to run, wait 10 long minutes. After that the security light will turn on steadly (will stop blinkling). Turn off, then start the car. It will now turn on.
This is a common issue with PASSLOCK II from what I read. If it happend more, it may need replacement. As to what to replace, I'm not sure if it's the whole ignition switch or just a module. I had that problem on mine, however due to a different reason. Bugged remote starter and passlock II bypass module that give trouble. I ended up bypassing the protection with a resistor.
Thursday, July 30th, 2020 AT 2:12 PM
