There are 2 likely hings that can cause this, and 2 unlikely but possible.
The likely things are a blownheadgasket/warped head, and a bad manifold gasket if it is a wet type manifold.
The two unlikely thigns are is the block is cracked or someone dumped oil in the antifreeze or vice versa.
Best thing to do is buy a compression tester and check the compression to see if its head/headgasket related or no.
SPONSORED LINKS
Sunday, August 10th, 2008 AT 11:18 AM
