1998 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
Low coolant light came on, level was indeed low, no visible coolant leaks, checked all other fluids. Oil was orange-ish in color. I'm assuming this means one or more of the following- intake manifold gasket leak / head gasket leak / cracked cylinder head / engine block damage. Is anyone of these areas more likely than another to be the problem given my make/model/etc. 135,000 miles.
SPONSORED LINKS
Sunday, October 24th, 2010 AT 10:21 AM
