2001 Pontiac Grand Am 01 Pontiac Grand Am, Won't start.
PONTIAC01
  • 2001 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 104,000 MILES
Hi, I have an 01 Pontiac Grand AM. It will not start. When you turn the key all the stero lights etc. Come on but it just clicks once and does not turn over. Checked the spark plugs, oil, etc. Not sure what could be causing it. Any ideas?
Tuesday, July 28th, 2009 AT 7:20 PM
Check Ign switch batt1 40amp fuse if okay
Check the battery connections if okay -short out the stater solenoid if it cranks over-starting check the park and neutral switch and ignition switch
Thursday, July 30th, 2020 AT 2:22 PM
PONTIAC01
  • 8 POSTS
I was going to try shorting them out but the starter acts as if its going to turn the motor and gets really hot, but won't start it.
Pull the starter and get it load tested.
