2001 Pontiac Grand Am car won't start but lights come on?
TRULYME88
  • 2001 PONTIAC GRAND AM
2001 Pontiac Grand Am Automatic
my car has a problem where when it's cold in the car, it won't start. I turn the key over all the way to the right and all I hear is "tick" and that's it. Some lights some on and go back off trying to start it but like I said, every time I turn key over to right all the way, I just hear "tick". It's just one tick I hear. I don't know what to think.
the shop replaced the bad battery that was corroded and such and cleaned the cables and everything for the new battery and it was perfect for couple days until this morning I tried to start it and it was a little cold in the car and it wouldn't start. It did the same thing. It finally started and I drove it around for a little while with heat on. Turned it back off and started it back again perfect after it warmed up.
why won't it start when it's cold? The lights come on and everything when I turn key to right but won't start. Only when it's cold it won't start? Anyone know what might be wrong with it?
Sunday, October 25th, 2009 AT 10:26 AM
MMPRINCE4000
  • 8,548 POSTS
Take car to any autoparts store and have charging system tested for free. They can check battery, alternator, starter and any drains on battery.
Starter also gets its ground from block, so make sure starter is properly grounded (oil around starter base could cause intermittent loss of ground).
Thursday, July 30th, 2020 AT 2:21 PM
