2000 Pontiac Grand Am Wont Start
ZOBRIANT
  • 2000 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 130,000 MILES
A friend asked me to replace the head gasket on her car. The car has been setting 3 months so. The last time she drove it it was pouring smoke out of the exaust and over heating. The water pump was replaced shortly before because of overheating. So I replaced the head gaskets and all of the other seals on the top end. I cleaned everything in the process. When I crank the motor it turns then kicks back. I thought it was flooded so I pulled the plugs to air it out. It still does the same thing. It blows back through the intake. I hooked a OBD 2 scanner to it but it did not tell me anything. I think its the timeing but I dont know how to check that. Ive got Commpression, Spark and Fuel!
Thursday, January 10th, 2008 AT 1:21 AM
I don't think you got the firing position right for the valve and ignition timing, you're going back in and pull a CSI on the sprockets alignment at TDC on No.1 compression stroke.
Something don't Jive.
Thursday, July 30th, 2020 AT 2:18 PM
