2000 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
KEY WILL NOT TURN, STEERING WHEEL IS NOT LOCKED INTO PLACE, BUT CANNOT TURN KEY TO START
Wednesday, October 20th, 2010 AT 1:10 PM
SATURNTECH9
MECHANIC
What position is the cylinder stuck in?Also does the key come out if so does the key look worn down?
SPONSORED LINKS
Wednesday, October 20th, 2010 AT 1:28 PM
DILLARD3
MEMBER
IT IS IN PARK KEY IS NOT WORN DOWN
Wednesday, October 20th, 2010 AT 1:33 PM
SATURNTECH9
MECHANIC
Try popping off the ignition cylinder bezel and tapping lightly on the the key hole with a hammer and see if the key will turn then.
Wednesday, October 20th, 2010 AT 2:04 PM
DILLARD3
MEMBER
WHAT IS THE BEZEL
Wednesday, October 20th, 2010 AT 2:20 PM
SATURNTECH9
MECHANIC
My mistake you don't have a bezel on that car. You need to find a small enough ball pen hammer that the small end of the hammer fit's between the the two tong's of the cylinder then tap on the key hole.
