2000 Pontiac Grand Am Car stops in the middle of driving
OBRISKIEBA
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • MANUAL
  • 10,000 MILES
What should we be looking for if the car stops at about 20 minutes into driving it? The engine cuts out and it will turn over but won't start back up.
Wednesday, February 4th, 2009 AT 4:04 PM
JDL
  • 16,098 POSTS
Hello, can you check for codes? Can you do some of the basic tests? Have a helper crank it, while you check for spark at the plugs. Can you check for injector pulse, with the engine cranking?
I realize if you have the IDI ignition system, the plugs may be awkward to get at. If the electrical connectors for the ignition module are accessible, you can do some testing, there.
Thursday, July 30th, 2020 AT 5:30 PM
