2000 Pontiac Grand Am
ANGIEANDERSON
  • 2000 PONTIAC GRAND AM
I have a 2000 Grand Am that just will not start. It cranks but thats it. I also have trouble getting the ignition switch to turn, really have to work with it. I'm wondering if this could be part of the problem, maybe with the security. It started and run fine, with the exception of having to jiggle the key to start it, then I parked it, went back out about 2 hours later and all it will do is crank
Wednesday, September 1st, 2010 AT 10:18 AM
MMPRINCE4000
  • 8,548 POSTS
Try resetting the security system:
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position.
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it.
Thursday, July 30th, 2020 AT 2:19 PM
