Engine not running?
RLANE71
  • 1999 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 102,000 MILES
Running down the road car was fine. Made a turn on the interstae and headed down ramp. Getting car up to speed and it died. Pulled over and it will turn over but not start. Seems to be getting plenty of fuel. And thing I need to look at.
Friday, June 27th, 2008 AT 4:06 PM
LEGITIMATE007
  • 5,121 POSTS
I would check the crank shaft position sensor, but first check fuel pressure and spark, When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Friday, June 27th, 2008 AT 8:53 PM
