1999 Pontiac Grand Am Car won't start
CHVNC7
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • 120,000 MILES
Recently the car has been sluggish when I started it up. Just the initial two or three turns were sluggish and then once it started it would run fine. Occasionally the trunk also popped open when I would attempt to start it. Yesterday it stopped starting altogether. It turns over but it slow and then just won't start.
Tuesday, September 8th, 2009 AT 8:50 AM
RACEFAN966
  • 5,029 POSTS
Ok if I understand correctly it turns over slowly but will not actually start? If this is correct I would like you to pull the battery out and take it to a parts store that does battery testing and test it. If you have a charger charge it first so it has a good charge before they test. Also ask that if the battery is low if they will charge it for free most will. Get back to me and we will see were to go from here.
Wednesday, July 29th, 2020 AT 10:01 AM
CHVNC7
  • 5 POSTS
For the past week it would start up but it was it turned over two or three times sluggishly and then would start, but now it will not start. I will take up the battery tomorrow and get back to you. Thank you
RACEFAN966
  • 5,029 POSTS
Ok that will work let me know what you find.
