1999 Pontiac Grand Am no fuel
1999 PONTIAC GRAND AM
177,273 MILES • 6 CYL • FWD • AUTOMATIC
JJP607JC
i replaced everything just about and the fuel pump doesnt come on even though it was tested and works,tach doesnt move up when i had the engine running by pouring gas in the air cleaner.not sure what else i can do i tryed just about everything even changed the computer and all please help been spending 2 much money on this car
Jun 18, 2009 at 3:17 AM
MMPRINCE4000
  • 8,548 POSTS
You need to check fuel pressure at the fuel rail with a mechanical gauge. Even though you can hear the pump, it is the fuel pressure that runs the car.
Jun 19, 2009 at 1:01 AM
JJP607JC
i direct wired the fuel pump and got fuel to the rail but wasnt going any further the fuel pump gages and injectors dont turn on
Jun 19, 2009 at 10:26 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuses and spark, if PCM does not see an ignition reference pulse it will turn pump off.
Jun 20, 2009 at 1:06 AM
JJP607JC
has spark and fuses and relays are good
Jun 20, 2009 at 4:14 AM
MMPRINCE4000
  • 8,548 POSTS
If it has good fuel pressure at rail and spark, then check injectors with noid light, see if they are firing.
Jun 21, 2009 at 2:01 AM
