1992 Pontiac Grand Am 2.3L Quad-4
1992 PONTIAC GRAND AM
140,000 MILES • 4 CYL • FWD • AUTOMATIC
CBISHOP
  • 5 POSTS
Ok this car sat for about a year.. I replaced the ignition and the battery, Changed the oil and Filter and the air filter and while it was broke down I replaced the coil packs and spark plugs. It started and it ran for a few minutes and the would run very rough, I found a few Vacuum lines that were bad replaced them and it started right up and ran fine for a few days. Now it will die sometimes while it is Idling and then not start. If you wait a while it starts right up and runs fine.
Any Ideas?
Craig B.
Oct 23, 2009 at 2:23 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Do a scan and check for any unresolved fault codes, check the fuel pressure & flow, check for contaminants in the fuel, replace the filter if you have not done so already, see how that goes and re post if you still have a problem..
Mark (mhpautos)
Oct 23, 2009 at 6:41 PM
MMPRINCE4000
  • 8,548 POSTS
Remove the ignition module and have it tested free at any autoparts store in addition to the great advice by Mark.
Oct 24, 2009 at 3:19 AM
CBISHOP
  • 5 POSTS
The car is now in the shop, stopped running all together, I know it's fuel related but I haven't the time to fix it.. I'll repost with what the problem was!
Oct 27, 2009 at 1:11 AM
