1999 Pontiac Grand Am my car misfires
DAVE JONES 5550
  • 1999 PONTIAC GRAND AM
Engine Performance problem
1999 Pontiac Grand Am 4 cyl Two Wheel Drive
hello, my car misfires and runs rough then at mid range it smooths out I change o 2 sensors upper and lower change spark plugs ignition coles fuel filter regulator and cleaned throttle bore and throttle body air mass sensor and the car stills runs the sames please help I dont what eles to fix some one told me it could be fuel pump that will cost me another 200 I hate to do it if that will not fix the problem. What is there to do next? Thanks
Tuesday, June 1st, 2010 AT 10:00 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
Wednesday, June 2nd, 2010 AT 2:36 AM
