I have a bad miss in engine. I have changed sparkplugs, ignition module, coils, the plastic housing and plastic things that go over plugs, fuel filter, fuel injector, checked compression which is ok. Had the catalytic coverter checked ok. If you hold gas paddle down half way the engine will rev up and down but still misses bad. Any suggestions. Thanks.
SPONSORED LINKS
Saturday, March 6th, 2010 AT 1:33 PM
