1995 Pontiac Grand Am IDLE
CHUCK11SUE
  • 1995 PONTIAC GRAND AM
Engine Performance problem
1995 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
when I start the car it idles at 12 to 1500rpm and never idles down have installed a map and an idlepart forgot what its called
Friday, October 17th, 2008 AT 2:34 AM
BANSHEE05
  • 18 POSTS
is there any check engine light on, could be a coolant temperature sensor or a throttle postion sensor, also when you replaced the idle air control valve did you clean the carbon build up from the passage way in the throttle body? Other than a high idle does the car run well?
Jon
Saturday, October 18th, 2008 AT 12:45 AM
