Brakes problem
1996 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
HOW DO I CHANGE THE MASTER CYLINDER ON THIS CAR.
Monday, January 5th, 2009 AT 7:27 PM
TONYG21
MEMBER
Ok you should have two bolts holding the master cylinder onto the booster. What you need to do is remove the brake lines from the master cylinder. Then all you will have is the bolts holding it to the booster remove them and the master cylender should come right off.
