1994 Pontiac Grand Am removal
MIKEB456
  • 1994 PONTIAC GRAND AM
Engine Cooling problem
1994 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
how do you remove the fan or get it out of the car to remove the radiator
Thursday, September 18th, 2008 AT 12:29 PM
MMPRINCE4000
  • 8,548 POSTS
They are usually held in place with bolts or plastic push holders. Remove the electrical connector and look at the outer edges of the fans assy. For the holders.
If you suspect the fan motor is bad, first disconnect the electrical connector and apply 12V to the fan motors, if they run, then the fans are not the problem. Could be a relay, fan switch or fuse.
Monday, September 22nd, 2008 AT 7:47 AM
