Remove the radiator cap, start engine, add coolant (50/50) until full, when thermostat opens you should see the coolant moving in the radiator, if not then the waterpump is suspect.
If the engine has overheated, you may have a bad headgasket.
Also make sure the cooling fan is working.
SPONSORED LINKS
Monday, November 3rd, 2008 AT 8:51 AM
