1994 Pontiac Grand Am Power Windows
1994 PONTIAC GRAND AM
RICKKELSEY
Electrical problem
1994 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
I have 94 grand am four door ,the rear driverside windows will go down ,but it will not go back up is there a problem with the moter or something else??The switches do work
Apr 5, 2009 at 6:38 AM
JDL
  • 16,098 POSTS
You can't get the window up using the master switch or the switch in the door?
You may have to check the feed to the motor, switch in up position. If everything checks out, sounds like the motor.
Apr 5, 2009 at 7:00 AM
