I don't know if the battery leakage is connected to the headlite issue? If the brights work, but, the dims don't, there may be an issue with the dimmer switch.
I just wanted to add, if you want to test at the headlite connector, for the low beam, tan wire is B+, black wire is ground. The bright and low beams get feed through the dimmer switch.
SPONSORED LINKS
Thursday, February 5th, 2009 AT 11:19 AM
