Turn signal malfunction
QUICOMB1
  • PONTIAC GRAND AM
2003 pontiac grand am about 72000 miles, when I turn my turn signals off, my car continues to make the same noise that it makes when the turn signals are on, what's wrong?
Sunday, April 16th, 2006 AT 8:09 AM
LOSONE
  • 1,616 POSTS
It sounds like you may have a bad turn signal sw but I really don't know. It's an odd symptom. Do the light still flash on the car?
Sunday, April 16th, 2006 AT 10:11 AM
QUICOMB1
The lights still flash and everything, it just makes the clicking noise after I turn them off. Sometimes it makes the noise and sometimes it does not. It is very wierd and the clicking noise is very annoying.
Sunday, April 16th, 2006 AT 11:26 PM
LOSONE
  • 1,616 POSTS
Take off the under dash panel and see if you can determine where the clicking is coming from. Check the fuse panel and see if you hear a click from the 2 circuit breakers in the fuse box. Look and listen carefully, that is what I would do if I was doing the work. Let me know
Monday, April 17th, 2006 AT 3:54 PM
