2003 Pontiac Grand Am Blinkers
2003 PONTIAC GRAND AM
58,000 MILES • 6 CYL • FWD • AUTOMATIC
RATTLERS13
Without turning the swith to the turn signals you hear a really fast blinker sound that comes and goes. if you turn a blinker on it sounds normal. All blinkers and brake lights all work fine.
May 8, 2009 at 2:21 PM
ZACKMAN
  • 4,202 POSTS
If it is just the noise but no visual, it is possible that either your flasher unit or your hazard switch is faulty. Next time is happens, check your directional lights on the gauge cluster to make sure that they are not on. Try to locate where the noise is coming from. Try turning on the hazard switch as well.
May 10, 2009 at 9:19 AM
