Alternator job is to keep battery fully charged and supply enough power to run all systems
if engine start with a jump and die after the cable removed
and need jump again you suspect and check alternator and charging system
if need jump and start and you are good until you shut it off
you suspect battery
SPONSORED LINKS
Thursday, December 3rd, 2009 AT 6:11 AM
