Check the heater core/hoses could be clogged-up. Did you bleed the cooling system after you flush the radiator ( air lock ) Pump, Radiator, Thermostat, and Heater core are okay-check the air mix/blend/mode doors to include vacuum/actuators
SPONSORED LINKS
Monday, December 15th, 2008 AT 4:45 PM
