1993 Pontiac Grand Am engine overheating
LIVER
  • 1993 PONTIAC GRAND AM
Engine Cooling problem
1993 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 100.00 miles
will a temp. Sensor make a car run hot
Friday, May 28th, 2010 AT 9:17 PM
If the coolant temperature sensor or the engine temperature gauge switch is defective the electric fan motor will not come on therefore the engine will overheat nothing to remove the heat from the radiator
Saturday, May 29th, 2010 AT 1:04 AM
