1993 Pontiac Grand Am engine overheating
LIVER
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 10,000 MILES
Will a temp. Sensor make a car run hot
Friday, May 28th, 2010 AT 9:09 PM
  • 31,937 POSTS
Hi there,
No it will not, you need to check for external leaks, check pressure cap is holding correct pressure, check thermostat, check cooling fans are working and check for a part blocked radiator, if all these are OK, then you will have to investigate for a head gasket problem but do the simple things first.
Mark (mhpautos)
Saturday, May 29th, 2010 AT 1:25 AM
