1993 Pontiac Grand Am
KAYLINSMITH
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • 170,000 MILES
Air conditioner leaks into the passenger and driver side floor. I have looked and can not find where the leak is coming from. I think this caused the blinkers to stop flashing. The hazards flash but not the blinker. I tried finding the sensor underneath the dash board where the guy at the auto part store said to look. I can’t find it any where.
Single mom bought the car for my daughter. Trying to fix myself and not working to well.
Can you tell me what would cause the leak and maybe give me more insight on the blinkers?
Tuesday, August 25th, 2009 AT 9:02 AM
  • 109,867 POSTS
Is it water or coolant leaking? As far as the flasher, it should be in the fuse compartment. If you have an owner's manual, check it for exact location.
Tuesday, September 8th, 2009 AT 9:12 PM
KAYLINSMITH
It is water leaking and it only does it when the ac is on. It is almost like something is freezing while it is running and leaks through the dash board.
I did check all the fuses and they are good. Somebody told me to check under the dash board for a flasher relay. I did look but have not been able to find it yet.
Wednesday, September 9th, 2009 AT 7:29 AM
  • 109,867 POSTS
What has happened is the drain for the ac is plugged. Open the hood and along the fire wall on the passanger side, you will see a rubber hose going to nothing. Move it around to see if it is plugged. They usually get dirt in them near the end. If it becomes unplugged, water will run out.
Wednesday, September 9th, 2009 AT 7:41 AM
