1992 Pontiac Grand Am engine cranks but will not start
TMB795
  • 1992 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 177,255 MILES
Car first started with a misfire and then got worse engine would stall then exhaust got red hot
now I am not getting spark at plugs had ignition moudle tested came back good replaced both coils still no spark could the crankshaft sensor be the problem to the plugs not getting spark
Friday, January 8th, 2010 AT 7:54 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, January 10th, 2010 AT 1:34 AM
