1988 Pontiac Grand Am Putting an 88 eng in a 95
BIGALASKA
  • 1988 PONTIAC GRAND AM
Engine Mechanical problem
1988 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
Can you put an 88 QUAD 4 2.4L eng into a 95 with a QUAD 4 2.4L Is there any compications any concerns has any one done this Im worried about the motor mounts
Tuesday, February 17th, 2009 AT 1:25 PM
MMPRINCE4000
  • 8,548 POSTS
Your best resource is to call a junkyard and see what years are interchangable.
You may be able to use 88 long block and intake, exhaust etc. From 95, but you most likely will run into problems with crank sensors and other things (different connectors for example).
Wednesday, February 18th, 2009 AT 8:38 AM
