1997 Pontiac Grand Am Problems in Detail
1997 PONTIAC GRAND AM
TARESS.SMITH
1997 Pontiac Grand Am Automatic 107000 miles
im having a few poblems and i'm wondering if they all might be connected:\r\n
my grandmother gave me this car, she bought it brand new in '97 and has been the only owner besides myself. Just recently she had a diagnostic test ran on it and nothing was wrong. She gives me the car and now, a month later, all these problems start happening.
-first the power steering fluid starts leaking everywhere
-then it begins to overheat when idle
-after that, it overheats just whenever its driven
-lastly, and most importantly my engine is ROCKING. that cant be good.
can you please tell me if a motor mount being broken has anything to do with the engine rocking, and if that affects all the other parts in the car? Thank you!
Aug 30, 2010 at 5:32 AM
BILLYMAC
  • 2,204 POSTS
Hi taress
No these probs are not related.power steering has to be a power steering pump or a rack and pinion these are the worst case .
it could be just a power steering hose leaking
overheat at idle.. this could be a thermostat failing pretty minor repair
overheat while driveing this could be head gasket thermostat water pump low coolant cooling fans not working. low on coolant.
Sep 11, 2010 at 2:30 PM
