2005 Pontiac G6 Electric Windows
2005 PONTIAC G6
48,000 MILES • 6 CYL • FWD • AUTOMATIC
D MILLIGAN
Front passenger side window will not operate. Fuses are OK and window switches are OK. All the other windows operate normally.
If it's the window motor that's bad, how do you remove the door panel to get to the motor?
Jan 24, 2010 at 5:30 AM
  • 110,240 POSTS
There are a few screws that need removed and the arm rest. Once they are off, the panel is clipped to the door. Be careful removing it so you don't break any of the clips.
Once in the door, check to see if the window is getting any power. THere are two wires. One gets power for up and the other for down. THe motor is grounded throught the door. IF there is power, the motor is bad. If there is no power, recheck the switch to see if it has power.
Let me know what you find.
Apr 19, 2010 at 3:18 PM
