2006 Pontiac G6 Automatic Windows
2006 PONTIAC G6
47,770 MILES • 4 CYL • 2WD • AUTOMATIC
CHECKMEOUT699
  • 5 POSTS
I have a Standard Sedan 2006 Pontiac G6, my automatic windows are not working, I have checked the fuses and they are all good, but still the passenger window will not go up. Now none of the windows work at all. Please Help! What do I do?
Jan 12, 2009 at 6:06 AM
BRIAN 1
  • 1,030 POSTS
the pass window will not go up?go up all the way,or just doesnt work?will it go up from the master window switch?need info and will advise.
Jan 12, 2009 at 6:19 AM
CHECKMEOUT699
  • 5 POSTS
the passenger window is down 2-3 inches and does not work at all, none of the windows work at all from any door panel.....Please Help!
Jan 12, 2009 at 6:32 AM
BRIAN 1
  • 1,030 POSTS
before I help need to answer a question,is this vehicle a hard top convertable?does this vehicle have a power sunroof or heated seats?I need to know so I dont lead you in the wrong direction.
Jan 12, 2009 at 6:45 AM
CHECKMEOUT699
  • 5 POSTS
The vehicle is not convertable, it does however have a power sunroof, but not heated seats. Thank you for all your help Brian!
https://images.2carpros.com/forum/automotive_pictures/300718_m_1de0134400c122bccb76c2d29b3c29ee_1.jpg
Jan 12, 2009 at 6:52 AM
BRIAN 1
  • 1,030 POSTS
this is the reason I asked,look at the info:A customer might comment that the Power Sunroof, Windows, and/or the Heated seats are inoperative. There have been reports from dealers that the 10 amp roof/heat seat fuse was open in the BCM.
Recommendation/Instructions:
Cause:
Dealers are finding that circuit #243 (YEL) wire, going to LH and or RH Heated Seat switch was found to be shorted to ground at the seat track. Dealers are finding the wiring in the driver or passenger seat was getting pinched by the recliner mechanism for easy access seat operation.
Correction:
Remove the driver and passenger seat outer bezels and inspect for damaged wiring to the heated seat switch. If damaged wiring is found, make the necessary repairs and re-route the harness as needed.
follow this info if it doesnt work post back and will advise on next step.
Jan 12, 2009 at 6:58 AM
CHECKMEOUT699
  • 5 POSTS
I think I may have confused you, my car DOES NOT HAVE HEATED SEATS, it DOES have power sun roof and it DOES work, but none of the side windows work.....
Jan 12, 2009 at 7:03 AM
BRIAN 1
  • 1,030 POSTS
make sure the window lockout is not on.you will have to remove the master window switch,and test the accessory voltage circuit of the driver window switch with a test lamp that is connected to a good ground see if it lights.it's the yellow wire.post back with what you find.
Jan 12, 2009 at 7:24 AM
CHECKMEOUT699
  • 5 POSTS
We tested the yellow wire with tester and it did light up on both the driver master switch and passenger side switch...... What next?
Jan 12, 2009 at 5:56 PM
BRIAN 1
  • 1,030 POSTS
this will be easier to follow:Verify that all of the power windows are inoperative.
Do the power windows operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
3
Disconnect the driver window switch.
Turn ON the ignition, with the engine OFF.
Probe the accessory voltage circuit of the driver window switch with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
Go to Step 4
Go to Step 5
4
Connect a test lamp between the accessory voltage circuit of the driver window switch and the ground circuit of the driver window switch.
Go to Step 8
Go to Step 9
5
Test the accessory voltage circuit of the driver window switch for a short to ground or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 11
Go to Step 6
6
Test the power window master switch lockout signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 11
Go to Step 7
7
Test the appropriate power window motor control circuits or appropriate power window master switch signal circuits for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 11
Go to Symptoms - Computer/Integrating Systems in Computer/Integrating Systems
8
Inspect for a poor connections at the harness connector of the driver window switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 11
Go to Step 10
9
Repair the open in the ground circuit. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 11
10
Replace the driver window switch. Refer to Front Side Door Window Switch Replacement - Left Side .
Did you complete the replacement?
Go to Step 11
11
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
try this and post back with what you find.
Jan 13, 2009 at 2:34 AM
JBARTON88
I also did those steps and the driver side window switch makes a humming sound when pressed.
May 17, 2011 at 4:05 PM
JBARTON88
The driver side window switch makes a buzzing sound.
May 17, 2011 at 4:27 PM
