1986 Pontiac Firebird No Start After Sitting
GODSCREATION
I have a 1986 Pontiac Firebird. I parked it for 2 years without starting the vehicle. Now it won't start. It just turns over. Before I parked it, I installed a new engine and the car started on a dime. Is this possibly a fuel problem? A friend said it is the fuel pump, but I do not see how the pump could get damaged by just having the car sit.
Nov 9, 2007 at 9:30 AM
BLACKOP555
  • 10,386 POSTS
it is possibly a fuel problem, if you stored it with a full tank of gas then chances are the pump is corroded and before trying to start it i would replace the fuel filter and drop the tank and clean it out and put in fresh fuel
with that done check for spark and fuel at the fuel rails. post back if you have spark or fuel or both or neither and we can continue.
Nov 9, 2007 at 11:59 AM
GODSCREATION
Thank You for your reply. I have already tried to start the car, would that cause further problems? I checked for a spark and got a positive result. I will replace the filter and clean out the tank, thanks again
Nov 9, 2007 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
when you disconnect the tank it should drain out the old gas. if you have spark then i can say its fuel related. how much voltage you getting at the fuel pump connector? if your getting voltage then replace the pump, if not check the fuse, relay and wires for cuts and cracks.
Nov 9, 2007 at 11:03 PM
Suggested Repair
Because the engine has spark, treat this as a fuel problem after long storage. Drain the old fuel, replace the fuel filter, clean the tank, and add fresh fuel. Check voltage at the fuel pump connector; if voltage is present, replace the pump. If not, inspect the fuse, relay, and wiring for damage.
Conversation Summary
A 1986 Pontiac Firebird that started well before being parked for two years now cranks but will not start. The owner suspected fuel delivery, and the expert agreed that old fuel and a corroded pump are possible. After the owner confirmed spark, the expert advised draining the old gas, replacing the filter, cleaning the tank, and checking pump voltage, then the fuse, relay, and wiring if voltage is absent.
