2001 Pontiac Firebird High Idle
RONNY HANCOCK
I have 2001 Pontiac Trans Am with high idle problem. Any time the engine is started the engine idle is normal (800RPM). While shifting the car(cutch disengaged), if the RPM is raised above 2400RPM the engine idle will remain at this RPM and slowly lower to about 1500RPM. I have checked throttle cable for kinks and binding. None found. I have checked the throttle plate for sticking and binding. None found. I have replaced the air idel valve. No effect. I checked for vacume leaks. None found.
Please advise what else I should look for.
Jul 23, 2007 at 10:23 AM
CLY
  • 308 POSTS
Check the pcv valve system....I take it that the car has a 5.7 liter engine???
Did it just start doing this all at once or was something done to the car and then it started doing this?
Cly
Jul 23, 2007 at 10:46 AM
Suggested Repair
Check the PCV valve system. Also confirm whether the engine is a 5.7 liter and whether the high idle began suddenly or after other work.
Conversation Summary
The owner of a 2001 Pontiac Trans Am reports a normal idle of about 800 RPM at startup, but after raising engine speed above 2400 RPM with the clutch disengaged, idle stays high and slowly falls to about 1500 RPM. The throttle cable, throttle plate, idle air control valve, and vacuum leaks were already checked without finding the cause. The expert recommends checking the PCV valve system and asks whether the car has a 5.7 liter engine and whether the problem started suddenly or after recent work.
