1994 Pontiac Firebird no start
BBSKI72
  • 1994 PONTIAC FIREBIRD
Engine Mechanical problem
1994 Pontiac Firebird V8 Two Wheel Drive Automatic
was driving and stalled let sit a little and it fired up drove a coupe of miles then stalled again and will not start any more replaced the distributer and still nothing
Thursday, December 4th, 2008 AT 11:16 AM
Check the fuel pressure make sure its within specs then comeback with the readings this is where we start. Or you can do below
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, December 4th, 2008 AT 1:30 PM
