1994 Pontiac Firebird Engine will not turn over and start
J LOWDER
  • 1994 PONTIAC FIREBIRD
  • V8
  • MANUAL
  • 94,000 MILES
My car has been running fine up to this point. The car will not start up. I have a full tank of gas, repaced the fuel filter, and have listened to the fuel pump each time I try to start the car to make sure it is working (it is). My car is still not firing up. The starter sounds like it is working just fine, and there are no codes flashing on the panel that would suggest problems, I am not noticing any other problems with the car besides it refuses to start. Can you give me any further suggestions please? Thank You soo much.
Monday, January 7th, 2008 AT 3:40 PM
MERLIN2021
  • 17,250 POSTS
Determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
If no spark test coil and ignition module.
Monday, January 7th, 2008 AT 3:56 PM
